C
Originally Posted by 02 LW300
(Post 59425)
If you drained the 4t45 transmission by dropping the pan you need 7 quarts to refill to the proper level. |
I am concerned for you, in my 40 years as a mechanic I have never had a torque converter quit with no other symptoms. I have had pumps fail and therefore a dead transmission. I think you may need a second opinion. |
I'm a little concerned now as when we pulled it
Okay so now I'm concerned a little more as we pulled the tranny found out the tranny has a number on it CEK7294PS OR DS
like the numbers wrecking yards and such put on side but I also found out my tranny is not the 6T40 But the 6T70 I cannot locate where this tranny came from I'm now at a loss the other torque converter I bought is to big so I had to order a new one double price for this other tranny omg I wish I had one of my friends here that lives closer to help me I'm desperate to have my car back please help Also found a paper with parts numbers but cannot find online (S) 29830547 Second number Part#(p) 15898468 Can someone please help me |
Have you looked at the wiki article about the problems with pre 2009 6t70 transmissions? I think you need help from a transmission professional at this point. |
ok,
How many times did i tell you to CHECK THE VIN with a dealer? You have an AURA XR not an AURA XE. The Aura XR came from the Factory with a 6T70. They are notorious for 3,5,R waveplate failures, causing shift flares (speedometer up, the vehicle goes nowhere. in 1st to 2nd, 3rd o 4th, 5th to 6th gear shifts. You also eventually lose reverse along the way. How do I know this? Because I went through it with a 2008 VUE XR w a 6T70 in it. Extended warranty from GM is 10yrs, 100,000 miles and now hey are being asinine and will only replace it for free if you lose reverse. Even though all four gears are affected. IF yours is a 2008, find out the date it was put in service by the original owner from a GM dealership.. If you are over 100K, forget it. Too late. If it is a 2007, too late. If my symptoms match your symptoms gear for gear, its a 2500 complete tranny rebuild due to the amount of things they need to remove to get to the waveplate to replace it. KIf too late, best bet is to buy a used one and check the vin to see if it had been repaired before you put money into it and end iup in the sa,me place |
Not an xr 2009 Saturn XE verified
Derf
mine is a 2009 Saturn Aura XE verified Now the problem is we pulled tranny and what I thought was the tranny you told me I ordered a new torque convertor it was for the 6T70 not the other one that we thought or was told by the GM dealer I cannot find any info on this damn thing but I do know that according to my torque converter my transmission is the 6T70 |
Vin
My vin is 1G8ZS57B59F214069
i don't know anymore |
my 2009 Saturn aura xe 2.4 L 4
That is what you sent me in a private message waaaaaay back at the beginning. -----------------------------------
XE (2008) 2.4 L LE5 DOHC I4 2,384 cc (145 cu in) 169 hp (126 kW)160 lb⋅ft (217 N⋅m) 4-speed 4T45-E XE (2009) 2.4 L LE5 DOHC I4 2,384 cc (145 cu in) 169 hp (126 kW)160 lb⋅ft (217 N⋅m) 6-speed 6T40 XE (2007–08) 3.5 L LZ4 OHV V6 3,510 cc (214 cu in) 219 hp (162 kW)219 lb⋅ft (297 N⋅m) 4-speed 4T45-E XR (2009) 2.4 L LE5 DOHC I4 2,384 cc (145 cu in) 169 hp (126 kW)160 lb⋅ft (217 N⋅m) 6-speed 6T40 XR (2007–09) 3.6 L LY7 DOHC V6 3,564 cc (217 cu in) 252 hp (186 kW)251 lb⋅ft (340 N⋅m) 6-speed 6T70 Per the above table, IF your Aura is a 2009 XE, it has a 6T40. Only the 2007-2009 Aura XR's w the 3.6L V6's shipped with the 6T70. The sensor I researched for you was for a 6T40. Further examination of the GM catalog listing for the part shows it is NOT compatible for use on a 6T70. So I really don't think it would fit a 6T70. If you decode your VIN online, it will tell you you have a 6T40. If someone had bought a 2009 xr, V6, blewthe engine, and replaced it with a 2.4L and retitled it as an XE--in theory, they would be in the same car. but it's a different block, different torque converter, the 6T70 has diff gear ratios. You'd have P0700 tranny flags for the rest of eternity. Have you considered the possibility that you made a BOO BOO ordering the torque converter the first time? Just because you ordered something that seems wrong for your application does not indict other parts of the car. I will research Torque converters for a 6T40 if you will pm me what you ordered the first time. We all make mistakes. Apologies if my words seem terse, but sometimes people only take notice of what is said if they are the slightest bit offended by it. I will take that chance 100 out of 100 times if it results in helping 1 person who has not responded to other means. I'm actually trying to help you to STOP ordering parts on educated guesses by some mobile mechanic that in all likelihood has never seen an aura before. One set of symptoms can be the result of 76 different conditions. My point is, it might be the torque converter---or it might not be. If your income is that limited, stop throwing money at parts until the root cause is determined. THe 2.4 ecotec and the 6T70 never met on the production line and don't mate up. |
It is the 6T40
https://cimg8.ibsrv.net/gimg/www.sat...08fe68efd2.png
https://cimg9.ibsrv.net/gimg/www.sat...2a8c22d8d7.jpg https://cimg0.ibsrv.net/gimg/www.sat...6e48caccac.jpg https://cimg2.ibsrv.net/gimg/www.sat...3db5ed05c8.jpgTag on my tranny cross reference number it is 6T40 https://cimg3.ibsrv.net/gimg/www.sat...59ec470c0c.jpgThe torque convertor I took out |
ok,
sorry about the mess of the table. It pasted into my message fine but got fubar'd when it posted. I wrote that message on the run and did not look. MY BAD. Thank you for the info. I will dig around and see what I can find Derf |
