Car is stuck on stupid lol
Okay so I bought car used and the head was blown replaced engine and it ran like a dream no problems at all then I noticed a little hopping and then found out the input output sensor was cracked thank you derf.. for helping me
after I changed that 60 minutes I also changed the tranny fluid not filter or gasket not yet I was told 4.5 quarts I bought 9 because based on specs I needed more so started it up took off ran great for a block boom hopped again and rpm reved speedometer bounced shut off started drove home I'm at a loss it purrs now when you start it There is a slight noise almost like power steering low noise I've owned car a year 8 months out of this year it's been down I desperately need a car please help no code other than p2430 Also the traction light keeps coming on and off |
(Post 59214)
Good luck with it, Lynn. Like I said, if you tell us where you are and we have a member in your area, they may offer to help you. If you're close to Lake Wales, Florida, I'll come help you. Two disabled people working on a Saturn. Someone would have to get video! LOL I'll expect a cold beer or two, though.
Originally Posted by 02 LW300
(Post 59420)
Ok Lynn let’s discuss your car and its problems. The p2430 is a secondary air pump issue and should not affect drivablility at all. What problems are you having, I suspect transmission problems since you asked for help with a sensor. We will help if we can! |
If you drained the 4t45 transmission by dropping the pan you need 7 quarts to refill to the proper level. |
(Post 59425)
Is there a drain plug on your trans? My Lw300 did not have a drain plug so I dropped the pan. Either way if you drain the pan it holds 7 quarts. |
Yes there is a drainplug on side they were saying the torque converter held approximately 3 quarts and not to put more in it should I add more to the car
From what I can find the transmission holds 10 quarts if completely empty. That includes the torque converter that holds 3. So I would put some more oil in it and see what happens. |
Found the problem torque convertor
Okay so finally got tired of it sitting so called mobile mechanic
no codes nothing the engine perfect no codes But after researching it every symptom it has points to the torque convertor so my questions is to verify my transmission is the 6t40 and the GM number I found 24239678 are there sub numbers For this part also found this part number but cannot get AutoZone to locate one 3230908075 please can someone help me thank you Please I need help |
The drain and refill on a 6t40 is 4.5 to 6.5 quarts. I would still try a little more oil. The transmission has to be removed to replace the torque converter. You may need a professional transmission shop help, they will be able to properly diagnose your problem. It may be a simple solenoid problem. |
