Adjusting the headlight
It's a 2008 Aura.
I did search you tube but nothing I found addressed the adjusting.
I watched a video of a guy replacing the entire headlight assemblies, and I'm not sure there's any type of vertical adjustment on them at all. I'm probably wrong, as they don't show the assembly in very much detail, just how to replace them. Good luck with it.
Go to gmpartsdirect.co (not c o m ) , look up your car and look at the headlight assembly.
If I was looking in the right place, it shows a vert adjustment external hex adjuster on the top center of the headlight.
2007 adjustment
So I'm deal6with same issue vertical adjustments but I did notice if I put my Phillips head in the top adjuster that says l&r for left and right it has adjusted my headlights vertically but I cannot find anything consistent
