Saturn Astra - alternator upgraded clutch pulley
Old Feb 23, 2026 | 11:19 AM
AstraFasta2's Avatar
Default Saturn Astra - alternator upgraded clutch pulley
GM issued a service bulletin for the alternators on Astras with automatic transmissions to address squeaking (and maybe premature wear on the accessory belt & components).
Bulletin No.: 10-06-01-001
Date: January 11, 2010
Subject: Chirp Noise from Accessory Drive Belt with A/C Compressor On (Replace Generator Pulley)
This is to upgrade the alternator's steel pulley with a modern clutch-pulley. I suspect this was not installed at the factory to save money. We DIYed the clutch pulley install. This upgrade stopped all squeaking on our Astra (the accessory belt and tensioner seem to last a lot longer too). The clutch-pulley is a nice addition.
Below are links to the TSB (includes instructions and pictures). Plus a brief primer on alternator clutch-pullies (aka overrun pulley).
https://charm.li/Saturn/2009/Astra%2...%20A%2FC%20ON/
https://www.gatestechzone.com/en/pro...function-tests
AstraFasta2
Saturn Astra
Feb 23, 2026 11:16 AM
Huggytree
Apr 2, 2021 09:48 PM
wcervant
Saturn L300
Dec 14, 2017 11:49 PM
Howard_Woodard
Oct 12, 2013 10:51 AM
jchubb01
Jun 19, 2012 09:16 PM
