Low Side A/C port location
Old Jul 24, 2019 | 05:54 PM
Bill Seaward's Avatar
Default Low Side A/C port location
OK, I tried really I did. Anyone know where the low side A/C port is on an 2008 Astra? It has a 4 cylinder ecotek Opel engine. Thanks.
Old Jul 24, 2019 | 11:09 PM
On my car it is behind the engine on the passenger side back by the shock tower down low. I would imagine it is in that area on your car. Follow the aluminum lines from the compressor back to where they go through the firewall.
Old Jul 25, 2019 | 02:37 PM
It should most definitely be in the aluminum lines. Follow Andy's advice and you shall find said port.
Old Jul 27, 2019 | 11:34 AM
Default Port location
Thanks Andy and DERF. That’s what I thought, but the AC charger would not stay attached. Perhaps a just need a better recharging unit. Any photos of this thing? I’m seeing a silver 1 inch or so, port coming off the line, and coming out of a flatter round disc looking piece. I see a valve stem in it, but there was no cap
Old Jul 27, 2019 | 04:28 PM
The connector on the hose from the can has to be firmly pushed on. It has some roller ***** that lock it in and if you just put it on there without a good amount of pressure, it won't lock on. You might try pulling up on the outside ring of that connector before pushing it on the aluminum connector. It's spring loaded.
Old Jul 30, 2019 | 06:14 AM
+1 what he said
Pull up on the outer ring of what you're connecting. You'll know it when you get it,
Old Jun 9, 2021 | 01:03 PM
TorontoGreg's Avatar
Any success? I have the same issue. I want to charge it with cans of Redtek 12a.
Old Jun 10, 2021 | 02:39 AM
I do believe this is an r134a system, so that may not be advisable.
It may also be why they won't connect. R12 and R134a connectors are different sizes to keep folks from accidentally using the wrong refrigerant.
Old Jun 10, 2021 | 11:56 AM
I got it to fit by oiling the charger's port. The O ring inside was very dry. The fit is tight but as it happens, a lot of hammering didn't help. I didn't hurt anything (luckily) but easy did it.
When I unscrewed the handle, the seal kept, pretty much, but it I thought there might be a slow leak as fluid dripped from the dial and the back of the dial froze up a bit. Also saw
some green liquid around the dial later. When I turned the motor and A/C on it slowly blew cool air, that was reassuring.
Shatrat
Jul 21, 2019 08:14 PM
TMunro
Jun 11, 2019 12:59 PM
Par2
Saturn Outlook
Jun 29, 2015 11:16 PM
Surkis
Sep 7, 2009 08:59 AM
projectpete19
Jun 15, 2007 10:23 AM
