There are different spline counts so count carefully. There are also different spline diameters. Hopefully they are exact copies of what came from Opel.
So when I set the inner one and hook in to the hub is the rod supposed to pull some from the inner side a Lil bit while it gets close to being tightened down all the way
The inner joint should move in and out inside the rubber boot. The outer end allows the wheels to steer the car. Little to no in and out at the wheel end.
