2008 saturn astra has codes p0300 p0302 p0303 p0313 p0172
Old Jun 9, 2019 | 09:24 PM
Justin Milami's Avatar
Default 2008 saturn astra has codes p0300 p0302 p0303 p0313 p0172
Replaced the cat, two coil packs, all spark plugs, and injector 1 and 3. Still runs super rich and clogged the brand new catalytic converters. Luckily they were replaced under warranty. Was thinking of trying the mass air flow sensor...any help is appreciated.
Old Jun 9, 2019 | 10:58 PM
Approximately 7 minutes of research indicates it is often the pre cat attached to the exhaust manifold that gets plugged up and causes the problem. Also the fuel regulator and filter need to be the GM OEM ones, because the aftermarket ones from the AutoZone and such run too high of a pressure which either forces the injectors to leak or just delivers too much gas per unit time. The po31 x( I can't see your post while replying) is a misfire code specifically at low fuel level in the gas tank. Po300, p0302, p0303 are all misfire codes as you know. Sounds like most likely the pre cat. If you had both of them replaced pre cat and under the car and they both immediately clogged again it would probably be because you have too much fuel running through, your engine is misfiring and not burning it, so you are pushing raw gas into the exhaust system which is just not good.
Also check before and after the MAF for vacuum leaks.
And check out this thread:
ODB II Codes Solutions - P0172 (your experience needed) - SaturnFans.com Forums
Please return and let us know what you found.
Old Jun 10, 2019 | 12:45 AM
Default Thanks
Thanks!!! I will check the precat and replace the fuel regulator and filter. Will let you know the outcome.
curiousv
Jun 16, 2018 10:58 PM
08astraxr
Saturn Astra
14
Nov 9, 2014 01:27 PM
chuckbattams
Mar 15, 2014 10:44 AM
RichardMc
Jul 28, 2010 06:18 AM
koundog1313
Dec 30, 2008 07:51 PM
