Transmission
Old Jan 16, 2012 | 10:10 PM
'98 Saturn SC2's Avatar
Default Transmission
This just started yesterday but its not the first time its happened. Out of the blue when I shift into or out of third it feels like its slipping but its not. Like I can push it into gear with one finger and not much pressure, but all the other gears are fine. I thought maybe it was the synchronizers but my mechanic said it wasn't. He didn't give me any information on it. He said give it a couple days and then go back if its the same. This happened before, back in September/October. All the gears engage and everything is working, its just really weird and annoying. Any idea of what it could be? I'm hoping that it isn't anything serious.
Old Jan 17, 2012 | 04:43 PM
So I found out what it is, but I don't know what the technical name for it is. I've been looking through all 3 of my books to find out what the name is. I was told by my father that it is the "shifter grommet" whatever that is? Any idea what he means by that?
Old Jan 17, 2012 | 06:02 PM
thinking this would be the shifter cable bushing that holds the shift cables to the shifter assembly. When it breaks, though, the entire shifter usually goes limp -- not just one gear.
You may have an issue developing with the bushing or with the shifter cable ends at the shifter or tranny linkage end
pull the center console (just screws I believe) and inspect both the bushing and the cable ends.
The shift busing goes when the cables stretch and create a lateral stress on it.
That's why GM will not sell the bushing alone - only the bushing with a new set of cables
Old Jan 18, 2012 | 08:56 AM
Shifter cables stretch out over time, thus the plastic bushings break and hard shifting is the result. You can try replacing them but be ready to go to the dealer and get a new cable set.
I say dealer because the aftermarket unit made by doorman is damn near junk.
Old Jan 18, 2012 | 11:06 AM
Damn near junk is right ...................
Bobbed06
Oct 31, 2012 09:09 AM
