Transaxle seal replacemnt
Old Oct 17, 2024 | 06:38 PM
Radtek2's Avatar
Default Transaxle seal replacemnt
Ok , I,m in the middle of an engine swap from a 97 to 98 SC2. I am using the manual transaxle from the 98 as the 97 was an automatic. I got the new clutch assembly today and new Flywheel will be here soon. I want to change both the transaxle seals while its out. Looking at them causes some concerns as for the best way to remove them. My understanding is one of them has a cap, a ring and then the seal. The other side looks more or less like any other seal. The seal Im concerned about got buggered up somehow during the engine pull. Do I go about this as any other seal replace or is there some thing I should watch out for?
have replaced. what is the best way to remove
Old Oct 17, 2024 | 08:06 PM
grcauto8453's Avatar
Hook under it and pry it out. Just take your time.
Old Oct 17, 2024 | 09:12 PM
Radtek2's Avatar
Thumbs up
Thank for the reply...that what I will do.
Old Nov 5, 2024 | 05:58 PM
Radtek2's Avatar
Default Transaxle seal surprize
I just wanted to mention in case someone with a 98 Saturn manual transaxle decides to change the seals there not both removed the same way. The Left side seal removes as every seal I have ever changed and that is a lot of them. Just use the seal removal pry tool and pull it out. Now the opposite side I went to remove the same way and manage to mangle and tear the seal all up and it would not move. In hindsight I should have clean it before I went to replace, but after a lot of colorful language I took a pin tool and felt around the edge of the seal and felt and obstruction. I sprayed it with some brake cleaner and saw it had a snap ring holding it in place! Now the Chilton manual and the youtube video I saw that was a Saturn Service Video did not show or mention this snap ring.
Snap Ring placement
Snap Ring placement
Seal before removal did not notice snap ring!
Old Nov 5, 2024 | 07:43 PM
Thank you for stopping by with the update
ding
Jan 31, 2020 10:46 PM
allen
Jan 18, 2012 11:01 AM
junior
Dec 2, 2009 06:34 AM
tonkota
Apr 13, 2006 03:51 AM
ZigZag
Mar 29, 2005 01:06 PM
