Transaxle Leak - 1996 SC1
Old Feb 25, 2008 | 09:05 PM
ding's Avatar
</>I am an experienced mechanic, just not any with Saturn so I am looking for input from those who are.
My son has a 1996 SC1 that has developed a Transaxle leak. The leak appears to be from behind the torque converted cover, which means that it is likely the seal on the torque converter. I read somewhere that an O-ring is used instead of the typical oil seal.
What is common on this vehicle?
What is the best way to pull the transaxle? Up or down? With engine or without?
Any input from knowledgeable Saturn folks is welcome.
Edited by: ding
Old Feb 26, 2008 | 04:34 PM
original007's Avatar
The o-ring is on the converter itself,there is also a normal type oil seal. if it is leaking badly the is a chance the diff came apart and cracked the case.best way is to pull it down
Old Jan 29, 2020 | 04:49 PM
TruthSword's Avatar
Correction: Since it was under the vehicle -- I am not certain which one it was. I know it wasn't the one on top of the engine. I had to replace it under the vehicle on the right hand side. I am not certain how to determine the exact sensor location. Does this error code "P0174 - System Too Lean Bank 2" throw for both upstream and downstream on Bank2? So I am certain it was Bank1 that I replaced (Just not sure downstream / upstream)
Do I just purchase both Bank1 downstream/upstream and replace them? Or is there a mechanical way of determining a rule out before purchasing parts?
Thank you again. Asking these questions are helping.
Old Jan 31, 2020 | 10:46 PM
You stated that the SES codes were cleared but that the light stays on after bulb check.
Would this not indicate the presence of codes that have returned?
Please re read the codes and repost.
codypet
Jul 19, 2009 06:19 PM
AudioPhyle
Aug 5, 2007 02:29 PM
96_SC2
May 25, 2007 04:36 PM
waldowarlord
Apr 13, 2006 03:54 AM
ZigZag
Mar 29, 2005 01:06 PM
