Saturn Coupe SC1 2001
Old Sep 14, 2007 | 11:03 AM
secondsaturn's Avatar
I just had a oil change, and on the bottom of the service sheet, it said "leaky transmission."
Is this a huge issue? Should I be noticing how the car runs? Is this imperative to go get it looked at right away? Edited by: secondsaturn
Old Sep 14, 2007 | 12:02 PM
01dbsc2's Avatar
is this an automatic, or manual? if its a manual, more than likely it would be the Axle Seals. If its automatic, could be the filter. Or something more serious. I know that saturn autotragics suck.
Old Sep 15, 2007 | 03:19 PM
the saturn is a manual. I will have the radiator flushed this fall, should I have them check the leak? And ask if it is the axles?
Old Sep 17, 2007 | 08:51 AM
Decipha's Avatar
yeah, have them take a look at it, idiots that noticed the leak should have been more specific on the work order, if the leak is minor it shouldn't be much of a problem, just don't let the fluid level get too low or you could burn up the trans
Dave4422
May 14, 2015 07:38 AM
pecos130
Sep 9, 2010 06:19 PM
Michelle100
Jun 3, 2010 07:01 AM
lukesteeler89
Mar 19, 2009 04:14 PM
blksti04
Mar 1, 2007 05:21 PM
