oil burn fix - maybe
Old Jun 24, 2007 | 09:31 PM
speedjunky's Avatar
Has anyone tried using straight 30 wait oil in there cars to reduce the oil burn in the engine?
I heard this from more than one engine guy and I'm trying to find out if it has tested before.Edited by: speedjunky
Old Jun 24, 2007 | 11:54 PM
ducky's Avatar
Straight weight oil is just a band aid, either seafoam or aMM soak in the cylinders overnight may loosen the carbon encrusted rings unless the valve stem seals are leaking. A compression test will point inwhich direction to go to.
RjION
News, Updates & Announcements
Nov 15, 2013 11:23 AM
wanderingjoe72
May 21, 2008 07:16 PM
a-NiC
Mar 21, 2008 06:29 PM
roastin300
Nov 19, 2007 08:44 PM
dman545
May 8, 2007 12:38 AM
