Newly purchased '01 SC2
Old Dec 1, 2010 | 11:10 PM
ambradley's Avatar
Default Newly purchased '01 SC2
I just bought a 2001 SC2 (5-speed) with a little under 67,000 miles. It has a couple of minor issues that apparently are common - random high idle, and a fog light switch that decides when it wants to turn on and off without any input from me (even when I try to turn them off, they usually won't turn off! At least they're only on when the headlights are on!)
For the random high idle (as high as 2000 RPM), I've read suggestions to clean and/or replace the IAC and TPS. I will take a look at them shortly. Are there any other recommendations?
I read at least one review of the car that mentioned the fog light switch issue. How difficult are they to replace? Is this problem so common that I shouldn't purchase a replacement switch from a wrecking yard?
Old Dec 2, 2010 | 07:51 AM
I've never had a foglight switch go bad.
Old Dec 2, 2010 | 06:18 PM
moi non plus.
Old Dec 4, 2010 | 09:08 AM
What 15 Saturns I've had over the years all with fogs but 3 .... and I've never had or heard of the switch going bad.
Old Dec 11, 2010 | 10:33 AM
Apparently not that common
Old Dec 13, 2010 | 12:30 PM
Nope - no defective fog light switches in my history either. One thing I would do, however, is to make sure I did an oil change ASAP, and at the same time check (and possibly) replace the radiator coolant
cdrob
Jan 18, 2010 12:12 PM
blind527
Nov 22, 2006 09:33 PM
