Instrument needles not lit.
Old Sep 5, 2015 | 04:56 AM
SC1-4Banger's Avatar
Question Instrument needles not lit.
What's the deal, it's all of them. the back lighting, etc; all work fine just the needles... any ideas?
Old Sep 5, 2015 | 08:50 PM
Bulb out or broken solder joint? I don't really know.
Old Sep 6, 2015 | 12:02 AM
think needles are lit by lights above and in front of the gauges. Maybe got jarred and broke a wire connection or solder trace/joint leading to those bulbs, or the ground could be lifted for the same reasons. No clue if they all share a common ground in the wiring harness but I can look it up if it comes down to it.
I would unfortunately suggest that you gingerly pull the cluster and first check the sockets for voltage. Could all just have blown at once, or, more likely, one blew without you noticing then the other 2 blew together.
Hopefully that's all it is.
_____
When you reassemble, put in all new bulbs while you're at it--the jarring fr removal and installation of the cluster will have likely stressed out some of the filaments
Old Sep 10, 2015 | 07:58 PM
saturnsctwo's Avatar
there's 2 bulbs in the top of the cluster on each side. pop the dash panel & they should be right on top... they are burned out for sure...
gambils2
Jan 16, 2015 10:01 AM
2timeowner
Jun 4, 2007 09:27 PM
gophaster
Jun 3, 2007 01:17 PM
AwolRJ
Mar 4, 2007 01:31 PM
50 caliber
Nov 27, 2005 04:56 AM
