Idler and Tension Pulley Parts?
Old Feb 28, 2022 | 08:31 PM
Take the belt off and spin each pulley component by hand to find the worn out bearing. Your mechanic should know to do this. Not sure who you are working with. The bad bearing will offer resistance to turning compared to the others.
Are you losing coolant or overheating?
Don't mess with that switch until you confirm you have 12 volts at one or the other pins in the connector versus chassis ground. If you are not getting power to the cutoff switch then you have other problems.
wcervant
Saturn L300
Dec 14, 2017 11:49 PM
RV Koenig
Engine & Internal
Aug 27, 2015 01:10 PM
Howard_Woodard
Oct 12, 2013 10:51 AM
jchubb01
Jun 19, 2012 09:16 PM
