engine swap donor car
Old Jun 22, 2014 | 09:41 PM
Gr8bawana's Avatar
Default engine swap donor car
I have 2000 SC1 that has 292,000 plus miles and has finally given it's all. It still
runs but has only about 110 lbs compression in cylinder all others have around
145 lbs compression. Doesn't run so good.
I have an identical car to take engine out of except that it has an automatic
trans and is a DOHC and the car it is going into is a SOHC with manual trans. Do
I need to change the engine control module with the donor engine? Or will it work with the module from SOHC engine?
If I need to change it will it plug in with no mods.
Also will the flywheel and manual trans bolt on ok?
Old Jun 23, 2014 | 01:46 AM
Read the swap guide posted in this forum. Most everything you need is listed.
Old Jul 4, 2014 | 03:53 AM
hoseppi's Avatar
You will have fewer headaches if you just replace it with another single cam engine.
DracoLoco
May 21, 2014 06:42 PM
Lastdefense05
Sep 5, 2006 02:37 AM
bugshield
Jun 17, 2006 10:15 PM
thoken
Jun 13, 2005 10:27 AM
jschrader
May 11, 2005 07:19 PM
