"Customize" Gear Shift
Old Nov 14, 2010 | 06:06 PM
Ender's Avatar
Default "Customize" Gear Shift
I just bought an aftermarked shift **** for my 1998 Saturn SC2. Lo and behold, it didn't fit. My gear shift was too thick for it, and it can't be forced on either.
What I was thinking was to take out the gear shifter from the shift assembly and then, first hack about an inch off of it, and then grind it to the correct shape so my new shift **** will fit.
Does anybody think this is a bad idea? Are there any problems that I could cause by doing this?
Thanks!
Old Nov 14, 2010 | 07:46 PM
Gee, that sounds like a lot of work. Why not bore out the hole on the 'aftermarked' (sic) **** so it'll fit?
As you will find with all "customizing", there's always a risk .....
Old Nov 14, 2010 | 08:58 PM
Basically I agree with OceanArcher. If you can install a small block Chevy V8 in one of these things as one member did, you probably can improvise a way to install a shift **** but the one you are suggesting sounds like doing it the hard way.
All it should take is the right part
or
Money
a big hammer
and a welder.
Old Nov 14, 2010 | 10:05 PM
i prefer spackle, a hammer, and duct tape personally.
I'm with them -- bore the **** -- simplify the job
Old Nov 15, 2010 | 12:11 AM
Ender's Avatar
Thanks for the ideas. I hadn't even thought of that. I guess I thought the new shift **** was too "precious" to do such a thing to it. Doing that would definitely be easier.
SF Help & Suggestion Center
Mar 25, 2012 10:55 PM
92SL2
Feb 25, 2011 01:42 PM
timmerz
Feb 9, 2011 08:56 PM
RattRod17
Jan 28, 2010 10:40 AM
irishgrrrl
Jun 14, 2009 08:27 AM
