Custom Storm TB
Old Mar 27, 2016 | 06:44 AM
Felixthekat's Avatar
Default Custom Storm TB
This is my original TB and the Storm TB that I am using now. You can just barely see the vacuum line elbow on one side. I broke the plastic pulley to get the butterfly shaft off, it is uses brads to hold it in place. I used a Dremel to cut them out but the shaft still wouldn't come out so I cut it, did the work and then used a fusion weld head to weld it back together using an Arc Machines Inc. M207 Power Supply and M9-1500 Weld Head with .375 clamps. I had to make an idle adjust stop as well but as you can see from the pic, I did it the old fashioned way: Beat on a piece of steel until it was the shape that I wanted and then bolted it on. My patience was running thin after all the work I put into this little project, it took me around 2 weeks working a few hours each night.
Attached Thumbnails Custom Storm TB-slightly-larger.jpg   Custom Storm TB-last-time-i-make-butterfly.jpg   Custom Storm TB-idle-adjust.jpg   Custom Storm TB-pulley-template.jpg
Felixthekat
Mar 27, 2016 06:23 AM
Felixthekat
Mar 27, 2016 06:12 AM
Nov 5, 2012 09:00 PM
dijon270
Jul 8, 2012 11:44 PM
got19s
May 1, 2007 05:17 AM
