-   -   Crank but no start (https://www.saturnforum.com/forum/saturn-3-door-coupes-28/crank-but-no-start-10758/)
Jeff smith Oct 27, 2021 03:07 PM
Originally Posted by derf (Post 64381)
In layman's terms, the ignition switch senses the key, that sensing signal talks to the BCM to say yep that's the right key, the BCM communicates to the ECU a password so to speak. The password must match what the ecu is expecting. If all this works out, the injectors are uninhibited, meaning the default state with passlock activated is to inhibit operation of the injectors.
The fact that you have no fuel at the rail would indicate to me an issue with the fuel pump or the electrical circuit that runs it including the fuse or relay. If you did not hear any noise when you turn the key on, then the fuel pump is not priming. Then the question becomes why.
Normally I would agree with you that no spark plus no fuel at the injectors points to CKP. However if there is no fuel at the rail, there is something not right before you can lay blame on the ckp.
The fact that your gas gauge is wonky May point at an electrical issue at the connections to the fuel pump. If the sending unit and the fuel pump are on the same circuit, you may have lost a ground which is keeping the fuel pump from running and also messing up the voltage signal sent by the sending unit as the ground side of that circuit may be floating.
Does your dome light work inside the car? Serious question.
no dome light does not work
derf Oct 27, 2021 08:12 PM
Please start your own thread with the background details so we understand the nature of your issue.
Thread closed
