CD Player Shroud Connectors
Old Nov 10, 2010 | 08:25 PM
Ender's Avatar
Default CD Player Shroud Connectors
Hey all, I've been searching for solutions to this problem for quite some time now, and have gotten nowhere. I am wondering if anybody knows where I can buy replacement pin connectors for my center console - these are the pins that you need to push a screwdriver into in order to take off. I broke both of mine when I replaced the stock radio in my 1998 Saturn SC2.
Thanks!
Old Nov 10, 2010 | 08:41 PM
May just have to go to the junk yard cut off the connector leaving enough wire to splice in the two you need to replace..
Old Nov 11, 2010 | 01:07 AM
Ender's Avatar
Thanks for the reply.
I figured I would probably end up having to do that. The plastic pin connectors aren't any part of the wiring; they are what holds on part of the center console. Here is a picture I found that looks exactly like my car's stereo.
The pin is the small circle on the side of the stereo. It holds on the "plastic covering", if you will, of the cd player. I've attached an image pointing at it, if my description is too vague.
Edit: I would take a picture of the pin itself, but I broke both of them when I took out my stock radio >.<
Attached Thumbnails CD Player Shroud Connectors-larue99saturnsl1-fvint-d-stereo.jpg
Old Nov 11, 2010 | 08:11 AM
Oh you need the fasteners that hold the trim on
Those can be had from the dealer ................... easy.
Old Nov 11, 2010 | 11:11 AM
Ender's Avatar
Thanks a lot. I didn't really know what the thing was called. Time to go to my local Saturn dealer.
Old Nov 11, 2010 | 09:18 PM
gm dealer that is
kelkay
Jul 19, 2008 04:46 PM
halofan00
Audio/Visual Electronics
May 18, 2008 04:33 AM
tweakers
Feb 14, 2008 08:58 PM
jamienfld
Oct 23, 2006 06:10 PM
turbo4door
Jun 11, 2006 02:47 PM
