Car won't stay running?
Old Dec 15, 2021 | 07:05 PM
IdahoRepo's Avatar
Default Car won't stay running?
So this 2001 SC2 sat for years. Fired up with a jump idled amazing for an hour or so. Second I tried to drive it, it sputtered and died. Has not ran since. To date we have emptied the tank and flushed it out. Filled with fresh fuel. Replaced fuel pump and filter twice... replaced crank sensor, tank pressure sensor, coolant temp sensor, new spark plugs, all new fuel lines, new injectors. We have fuel in the rail. It will start and run great for 45 seconds or so after it sits a while but will sputter out, die, and when you restart it just dies right away. Have fuel, have spark. Tested all the relays and fuses. They are GOOD the coils to be good as well as the ICM. Have injector pulse. WHY WONT IT RUN?
Old Dec 16, 2021 | 02:35 AM
Let me guess, you put your foot on the brake and it stops dead.
Battery cannot hold a charge. Likely ANY charge.
Zilch. Alternator output is likely fine but battery can't store any of the charge coming from it.
​​Although the alternator output supplies the vehicle with the current needed to run the PCM and ignition system, and in your case BCM, some of the output goes to keep the battery charged. If the battery is not capable of storing the charge, it basically goes almost straight to ground, thus greatly reducing the total available current from the alternator to run the car.
You can check the connections at the battery and the battery chassis ground for tightness and corrosion, but any battery left sitting attached to a car for years without being charged will bite the dust.
Old Dec 16, 2021 | 07:57 AM
I agree with derf. Take the battery and get it load tested first. If that doesn't work, do a compression test and check the air intake for any rodent nests. Maybe something has chewed wires or built a nest. IDK, I'm NOT a mechanic.
Old Dec 16, 2021 | 03:40 PM
My post above is from direct personal experience. And it only took 6 months
Old Dec 18, 2021 | 12:03 PM
Progress update?
Remember your follow-ups will help other members that follow....
Old Dec 21, 2021 | 05:50 PM
Making any progress on this?
Old Dec 22, 2021 | 08:13 AM
We'll never hear from that one again either, derf.
Old Dec 23, 2021 | 06:06 AM
I'm not so sure...
I'll continue to check indefinitely🙃
smacclintic
Sep 18, 2021 02:48 PM
benc48
Jun 16, 2015 10:01 AM
ffire
Jul 10, 2012 06:39 AM
ifitwasnt4u
Oct 1, 2009 11:52 PM
dane9499
Feb 4, 2008 08:46 PM
