Blower motor won't run
Old 10-03-2009, 05:17 PM
bfoley11's Avatar
Default Blower motor won't run
Hi, I have a 1999 SC2 and the blower motor will not run at any speed. I have checked the fuse, replaced the relay and resistor, ran a couple of wires from the motor to the battery and the motor worked. There is power at the blower motor and it if I turn the switch off the power goes away. Everything seems to be working. Have I missed anything to test?
Old 10-03-2009, 08:17 PM
Default RE: Blower Motor Questions
I think the key is in your statement where you (1) "ran a couple of wires from the motor to the battery and the motor worked", and (2) "There is power at the blower motor and if I turn the switch off the power goes away"....
I suspect the return lead in the regular wiring harness from the blower motor back to ground connection point is defective.
Old 10-04-2009, 06:22 PM
Ground?
Old 10-04-2009, 07:34 PM
Hmmmmm -- my bad. Guess all those years as a "twidget" are catching up with me ... I meant to say "negative return"
Old 10-05-2009, 05:27 PM
bfoley11's Avatar
Thanks, I will take a look at it this weekend.
tikidude
08-30-2014 05:04 PM
banshee
07-11-2013 02:58 PM
Nate_D33
06-30-2010 09:52 PM
allen21362
07-23-2008 03:00 PM
duganator
09-18-2007 09:39 AM
Quick Reply: Blower motor won't run
