2000 SC1...few ?’s
Old Apr 3, 2008 | 08:53 PM
homeline's Avatar
Hello,
Just picked up a 2000 SC1 for a daily commuter. Has SOHC & 5 speed. Run's and drives out very nice. But there are a few things I'm curious about.
First, in the morning after warming up for a bit the RPM's are about 900 +/- . Then taking off down the road and up shifting the RPM's stay at about 2000 for a second or so after letting off the gas pedal. They will drop if I coast. No problems after several miles and all warmed up. When warm and coming to a complete stop, RPM's stay at 1200 for a couple seconds or so than drop to 800 +/-. Is this normal?
Second, at highway speeds (60+) there is a very high frequency vibration. Almost unnoticable except that the rearview mirror makes the image slightly blurry and can barely feel it in the wheel and shifter.I don't think it's wheel, tire or suspension related. Perhaps something in the driveline? I had a similar experience in my Mercedes that turned out to be a driveshaft flexdisk that was bad. I'm guessing this car has no such thing, but perhaps worn subframe or motor mounts (Mercedes experience too)? Or is this normal?
Lastly, all electrical related stuff appears to work just fine. No blown fuses, dimming lights, etc. Again at highway speeds there's a sound coming from the dash/console area. Almost sounds like a solenoid clicking. It's not continous, happens at random, not casued by road surface conditions and makes no difference what (if any) electrical things are operating. Any ideas?
I realize I've got an old car with a lot of miles, and some of these things mentioned might be SOP. But if something is giving me a heads up of a potential issue, I'd like to nip it in the bud.
Thanks,
Cliff
Edited by: sw2cam
Old Apr 9, 2008 | 10:04 PM
homeline's Avatar
Update:
Seem to have traced high freq vibe to a well worn upper engine mount. Replaced it and things are much better.
Dash clicking sound was traced to a loose radio. The two screws were not tightened down. Was told by seller radio was recently replced. A simple fix.
Haven't investigated the (seemingly) high idle. Any suggestions??
Cliff
Old Apr 13, 2008 | 10:14 PM
sadurnSC2's Avatar
when your rpms float stick for a second than drop it sounds to me like your throttle position sensor is gunked up take the intake off and spray the throttle body down wit cleaner 2-3 times should stop that from happening
< src="http://www.google-analytics.com/urchin.js" ="text/">
< ="text/">
_uacct = "UA-939292-47";
urchinTracker();
Edited by: sadurnSC2
Old Apr 14, 2008 | 01:56 PM
Low Saturn's Avatar
You might also want to remove the throttle body then remove the IAC and clean up the back side of the throttle plate and the passages. They get pretty gunked up.
Old Apr 14, 2008 | 09:26 PM
homeline's Avatar
OK...Thanks for tips. I have a Haynes manual now, so next weekend I have some time I'll investigate further.
Thanks,
Cliff
budsjlm
Jun 12, 2009 11:03 PM
iturnbolts
Sep 21, 2008 12:05 PM
homeline
Apr 12, 2008 02:40 PM
bannock
Sep 22, 2007 10:54 PM
McLarenross
May 3, 2007 06:00 AM
