'08 Astra Headlights
Old May 3, 2016 | 07:12 PM
Evel Knievel's Avatar
Default '08 Astra Headlights
Looking for the complete headlight assembly ( right and left ) for an '08 Astra xr. Must be in very good to excellent conidition. Mine are yellowed on the inside. Maybe someone has a quick fix? Thanks
Old May 3, 2016 | 11:54 PM
Was car parked facing the sun all the time?
Old May 4, 2016 | 11:04 AM
Default Headlights yellowed
derf, Not sure how they got yellowed? Just bought the car and parts seem to be hard to find for the Astra. A one year only import to US. Other than the headlights, this things is like new. Thanks again.
Old May 4, 2016 | 03:36 PM
oops. You bought it used.
Apologies for dumbass question
Looks like you need
Part #13 (both L and R) on
LAMPS/FRONT
Part Numbers
GM Part # 93357457 LH
93357458 RH
You get more than just the lens for $300 each if you believe
HEADLAMP ASSY | Genuine GM | 93357457
____________
Many other parts houses have these for sale online.
________
Can't quite tell, but it appears the plastic front lens is removable, as there are various tabs around the edge, presumably for positioning in the headlamp opening on the vehicle. Meaning it is not encased. And I do not see a listing for a gasket or seal, which is strange.
Which is prob how crap got in there and sped up interior degradation.
Meaning you may be able to find a nice cheaper used pair and swap out just the plastic.
Also makes junkyards a viable option.
You may also need 2 mounting grommets 93171754. Not clear as some sites show it included, some show as a separate part.
Can you tell if the lenses you have look like they will come apart, and if there is at least a lower gasket?
Old May 4, 2016 | 04:31 PM
Default Astra headlights
Thanks derf. I have found both R/L side for $274 a piece. Not good, but not bad. There has to be a very small market for Astra parts here in the States, as one year only import. EK
Old May 4, 2016 | 05:21 PM
Have you searched on both ebay and amazon?
Old May 4, 2016 | 08:38 PM
Yes I have looked on e-bay and Amazon. Then I typed in the GM part #'s and found acouple deals bing. Go figure?
Old May 5, 2016 | 03:11 AM
LAMPS/FRONT
Part Numbers
93357458 RH
____________
I guess I missed reading between the lines, meaning seeking very good to excellent does NOT include seeking new. After pricing the new ones I now know why. Technically, new meets your criteria, but neither here nor there.
Meaning you may be able to find a nice cheaper used pair and swap out just the plastic lens instead of the whole assembly for a lot less money if the rest of the assembly is damaged.
Is this the case? Can you disassemble and swap just the front lens?
Seems like a highly unlikely possibility, but have you checked?
charles_384@msn
Nov 19, 2008 08:26 PM
davidric98
Nov 14, 2006 10:39 PM
Tarlacon
Aug 15, 2006 07:10 PM
Leadsled Coupe
Mar 12, 2006 02:16 AM
1995sc2DOHC
Dec 6, 2005 03:16 AM
