Tire/wheel match for max mpg! Aura
Old Dec 20, 2006 | 08:24 PM
bostonfan49's Avatar
Hi! Really interested in the Aura RX. What would one recommend for tire/wheel size for maximum miles per gallon Please serious question! I drive for max mpg. Thanks, Bill
Old Dec 21, 2006 | 12:03 AM
S-Turn's Avatar
I don't have an exact tire/wheel size to suggest, but consider the following:
Taller Tire = Less RPM = Higher MPG.
Shorter Tire = More RPM = Lower MPG.
Wider Tire = Bigger Contact Patch With Road = Less MPG.
NarrowTire =Smaller Contact Patch With Road =More MPG.
There's gonna be some other factors, such as tire tread, weather conditions, highway driving vs. city driving, etc. that will also affect the milage you're getting.
Old Dec 21, 2006 | 12:45 AM
All your info is great and correct...If the original tire size for the RX is 225-50-18, i was thinking of going to 225-55-18. The speedo would be off approx 2 mph. Larger diameter/lower revs/very slight change in handling. I could also go with a narrower 215 but then I think I would be compromizing handling.????
Old Dec 21, 2006 | 04:01 AM
S-Turn's Avatar
Yes, the handling may be a little less, but it's hard to argue exactly how much less cornering capability you'd lose. I will say one thing tho; for very wet conditions and for snowy conditions the narrower tire will not hydroplane as easliy and it will cut through the snow easier. just a thought
Old Dec 25, 2006 | 01:21 PM
A link that should help out. If it does not work it's only because you need to do the suggested upgrade.
http://www.miata.net/garage/tirecalc.html
ps: everything is compromizing to something otherEdited by: sw2cam
LarryG
Sep 2, 2011 08:17 AM
ryan@waggs.net
Mar 10, 2009 06:42 PM
crhammondusn
Jun 10, 2008 06:14 PM
willer
Apr 30, 2008 09:12 PM
Bosted32v
Jan 29, 2008 02:25 PM
