Stuck help please
Go ahead and access your BCM, if you can. Try just unplugging the connector and plugging it back in about a half dozen times. Make sure you have the ground cable disconnected from the battery. The plugging and unplugging will help "sweep" the contacts in the plug and on the BCM and may actually help. This will clean them somewhat and if a dirty connection is the problem, this should help. All that will cost you is a little time.
