Stuck help please
Old Sep 15, 2019 | 08:20 PM
Cnegulici92's Avatar
Cleaned every ground I could find even on the battery and tried to start it and it wanted to start but stalled right away
Old Sep 16, 2019 | 06:45 AM
Thanks for the answers. You didn't answer the security light question.. this passlock system actually continually checks to make sure the correct key is present even while you are driving so there is a small possibility triggered while you were driving.
Old Sep 16, 2019 | 08:05 AM
When I turn the key to the on position the security light flashes then shuts off and is off when I try to start the car
Old Sep 16, 2019 | 10:22 PM
ok scratch that off the list......
Old Sep 17, 2019 | 05:31 PM
Ok because I didn’t know what else to do I unhooked the negative battery terminal for about 30 minutes and after hooking it back up it ran for about 10 seconds
Old Sep 17, 2019 | 06:48 PM
Also the lights flicker when I turn the key to the on position
Old Sep 17, 2019 | 08:55 PM
gotta have those codes
Old Sep 17, 2019 | 09:12 PM
I’ve got a code scanner coming tomorrow and will have them. I haven’t been able to get a ride anywhere except to work
Old Sep 18, 2019 | 06:08 PM
U2105
Old Sep 19, 2019 | 08:07 AM
Apparently, the first thing to check with that code is that the ECM is tight and all ground connections are good. Watch this video and you'll get the idea of which bolts to check for tightness.
