Need help
Old 10-22-2018, 04:07 PM
Waldo194's Avatar
Default Need help
2000 ls2 gauge cluster quit working but still have lights. The power door locks quit working to and it's stuck in park
Old 10-22-2018, 06:50 PM
Do you mean SL2?
Old 10-22-2018, 06:56 PM
Waldo194's Avatar
No. Ls2
Old 10-22-2018, 07:14 PM
Did all this happen at the same time?
Old 10-22-2018, 09:30 PM
I’ll look after dinner
Old 10-22-2018, 11:12 PM
All the functions that you are having problems with are controlled by the body control module. It is bolted to the top of the glove box. I will check the power fuse diagrams next.
Old 10-22-2018, 11:22 PM
I would start with a good test light and test both sides of all the fuses. There are several that power the BCM in the under the hood fuse panel there are also fuse panels in both kick panels inside. If all the fuses check ok then I would pull and reinstall all fuses to sweep the connections in the fuse panels. I suspect that you have a bad BCM but check a few things first.
Old 10-25-2018, 04:01 PM
Waldo194's Avatar
Thanks
tlingbeck
11-15-2013 09:26 PM
oohrah
06-29-2011 05:48 PM
cellocellocello
10-13-2009 10:47 PM
pester
09-05-2008 03:25 PM
unseenworld
07-02-2007 12:37 AM
Quick Reply: Need help
