Need help
2000 ls2 gauge cluster quit working but still have lights. The power door locks quit working to and it's stuck in park
Do you mean SL2?
No. Ls2
Did all this happen at the same time?
I’ll look after dinner |
All the functions that you are having problems with are controlled by the body control module. It is bolted to the top of the glove box. I will check the power fuse diagrams next. |
I would start with a good test light and test both sides of all the fuses. There are several that power the BCM in the under the hood fuse panel there are also fuse panels in both kick panels inside. If all the fuses check ok then I would pull and reinstall all fuses to sweep the connections in the fuse panels. I suspect that you have a bad BCM but check a few things first. |
Thanks
