Arriving from Saturnfans
Old Jan 13, 2024 | 11:00 PM
lanxer57's Avatar
Talking Arriving from Saturnfans
It has only been a few days since I have been unable to access Saturnfans.com, but when my car is inoperable, my sister has nothing to drive. (it was a mistake to agree to share, I rarely see it) It is operational at the moment, but you can never be too prepared.
My car is a 1999 SC1, with the "third door" flap. It was originally grey, but the hood, and bumper cover are now blue after a minor accident. It is now on its third automatic transmission in 2 years. Very fun to drive compared to my parents modern SUVs.
Old Jan 14, 2024 | 06:52 AM
Welcome.
Do you have a question?
Old Jan 14, 2024 | 08:40 AM
The transmission lines and cooler need to be flushed when replacing the transmission. And if you're using the old torque converter, DON'T. It's probably full of crud and debris and you need to put a NEW one in when you replace the transmission again.
Old Jan 14, 2024 | 03:03 PM
grcauto8453's Avatar
What is the current problem? Tranny again? As noted above the swapper needs to do the flush. TC can be flushed but a replacement is best.
Old Jan 14, 2024 | 05:18 PM
lanxer57's Avatar
I did need to replace the torque converter at some point, because it failed, but how would it get full of crud?
Old Jan 14, 2024 | 05:23 PM
lanxer57's Avatar
There does appear to be a current problem with the tranny, the last time I drove it, it was slamming between what I assume are 1st and 2nd when pulling away from traffic lights. I will need to look at that when I address the loose steering shaft. It is loose on the steering gear where it slides over it just after the last U-joint, causing excessive play in the steering.
Old Jan 15, 2024 | 08:29 AM
The torque converter pulls the fluid through the transmission. The fluid is sucked into it and it spins and makes pressure that helps push the fluid through the valve body and change the gears. You should really do the research on your own. I'm trying to simplify it, but I don't always come across clearly. I'm brain damaged.
Old Jan 15, 2024 | 02:01 PM
lanxer57's Avatar
I always thought it was the transmission oil pump that built pressure, but I guess the torque converter probably does have something to do with it...
Old Jan 15, 2024 | 04:24 PM
The fluid pressure is developed by the pump. A weak pump will cause problems even with a great TC. The fluid system is a closed system that performs the shifts. The TC develops internal pressures that are not part of the closed system that does the shifting. If the accumulators, clutches and such were to be subject to the radical pressures and changes within the TC the tranny would not last long.
Old Jan 16, 2024 | 07:50 AM
Thanks for the explanation, Gary. That makes sense.
