Can someone help me find this part? I have a 2003 Saturn L200 2.2L Base Sedan and spent 3 hours looking for it with no luck searching "airbox pipe, tube, duct, hose, assembly parts, air intake parts, etc."
I'm getting code P0172 and I think this is the culprit. I'd be willing to replace it with anything that works, it's the lower pipe just underneath the air filter.
The rubber part is brittle and I had no luck taping it up so I need a replacement for the (removable) rubber part or the whole pipe.
No more searching until you post a picture of the entire part, please.
Googled "2003 Saturn l200 air intake"
Elapsed time: 3 min
Yeah m8, I wasn't taking the picture for this forum, I was taking it for myself to look up the # on the part.
I've seen that part and searched that exact thing and combed through newgmparts carparts advancedauto gmpartsbin wholesalegmpartsonline stockwiseauto. I was more or less hoping someone would have some way to look up the part with the number or know what pipe I'm talking about directly under the air filter inside the airbox. Thanks tho
If that is the air hose into the filter housing that disappears into the inner fender, it part of the intake silencer system. It will not cause a P0172 code. How does your car run? Does it get 30mpg? Is the rich limit code the only one? I have a factory service manual set for an 02 L series. The 03-05 is very similar except for some of the v6 sensor readings.
