Wipers won't shut off
Old Aug 28, 2010 | 08:35 PM
kaylapuppy's Avatar
Default Wipers won't shut off
I have a 98 Saturn SL.
When I turn my wipers on they will not shut off until I turn the ignition off.
Even when I just hit the wiper once it keeps going until I shut the car off.
Anyone have any suggestions as to what might be causing this ?
I tried disconnecting the battery for several hours, in hopes that it would reset something, but to no avail.
Please help.
Regards,
Kaylapuppy
Old Aug 29, 2010 | 09:07 PM
that's truly odd
Old Aug 30, 2010 | 08:09 PM
The wiper controls are function of the stalk on the steering column and the wiper motor. Something of this order would be a wiring connector problem or a problem with the stalk it self which is the switch for these functions, or some kind of a ground problem. It obviously is not going to be easy to solve.
so the first question is
how rusty is the car
another is
has some one been into the wiring installing aftermarket stuff.
the third question I can think of is
how good are you are trouble shooting an electrical problem
and i guess a forth question is, have you purchased a saturn service manual at your local auto parts store in order to get the wiring diagram?
Old Sep 12, 2010 | 10:19 PM
ChrisMo's Avatar
Unfortunately, Saturns have those "fancy" wiper motors which require a "park" signal. (tells the motor to stop when the wipers are at a certain position) Your wiper motor is probably not getting that signal. I'm not absolutely certain, but I'm pretty sure you're gonna have to change the whole wiper motor assembly to get rid of the problem .... unless the park signal goes through the switch and then it could be in the wiring.
Knuxo
Mar 10, 2011 04:12 PM
sl2noob
Feb 23, 2011 05:39 PM
dorax5
Jul 13, 2009 08:51 AM
earthquakes
Sep 24, 2008 08:51 PM
TCPAUL
Mar 17, 2008 09:27 AM
