Timing Chain replacement?
Old Jan 3, 2008 | 08:17 AM
95_SL2's Avatar
I just bought my 95 SL2 last week. This is my first Saturn and first car with a timing chain so that brings me to my question. How often should I replace my timing chain? The car has just shy of 160k miles, seems to drive extremely well with no known mechanical issues. Is there a timeframe that these timing chains should be replaced in order to prevent some major engine damage from breakage? I've always owned Chevy/GMC trucks and SUV's but bought this to save on gas so I'm in need of a little bit of education when it comes to Saturn motors
Thanks for the help and insight and I look forward to learning more about Saturns!!!
Edited by: sw2cam
Old Jan 5, 2008 | 09:20 AM
The timing chains on these cars usually last quite a while. I have seem posts with 200K+ on the original timing chain.
If you do not notice any grinding or chattering coming from the timing chain area (from beneath the timing chain cover) and the timing on the car seems ok, chances are the chain has not stretched too much to become an immediate worry.
An auto tensioning mechanism is in there compensate forslack caused by stretching, and the guides should keep it in its intended path. If you here grinding or chattering /rattling sounds, chances are the chain is stretched and is crying for help.
Never had one break on me in these cars, personally...
DerfEdited by: derf
Old Jan 5, 2008 | 10:16 PM
95_SL2's Avatar
Thanks for the info, Derf!!! That is something I'll keep in mind. I'm guessing that the sound is very noticeable?? Right now everything sounds pretty normal and it runs pretty smooth. For some reason I was envisioning this timing chain just all of a sudden breaking without warning and then being out of luck and a messed up motor. I guess just because of the unknown and being so used to one thing in my Chevy's and GMC's and now having to get familiar with this Saturn
On a different subject, do you know how to get the outter door skin off on the driver's side front door? It appears that the torgue head bolts only turn about a quarter turn. Then after that does the skin lift off or what? I need to find out what is making my window pop out of track when I roll it down(power windows) and was told that taking off the outer door skin was the easiest way to do it with these. Any help you can give would be awesome!
Thanks again.
Old Jan 5, 2008 | 10:47 PM
Remove the outside door handle
Remove the torks fasteners from the door (they screw out)
Remove the door skinEdited by: sw2cam
Old Jan 6, 2008 | 07:58 AM
95_SL2's Avatar
hmmm....then there is something really wrong with my car then because on both the driver and passenger front doors the Torque screws only turn a quarter of a turn. I haven't tried the back doors yet.
Old Jan 6, 2008 | 10:59 AM
Low Saturn's Avatar
They usually turn easily a quarter turn until the speed nut chatches. Then theres a lot of resistance until everything loosens up. Make sure you remove and install the bolts by hand. Using an attachment for a drill or air ratched tends to snal the speed nut right off the body panel.
Old Jan 6, 2008 | 11:48 AM
Low Saturn's Avatar
Thanks again.
I have a write up on my site,
Here ya go:
http://www.differentracing.com/tech_...1-95outerpanel .html
Old Jan 6, 2008 | 09:51 PM
95_SL2's Avatar
Thanks, Man!!! This should be very helpful!!!
95_SL2
Jan 15, 2008 06:22 AM
Classof84
Jan 12, 2008 05:55 PM
Racemare
Jan 9, 2008 09:43 PM
hartman
Apr 3, 2007 01:14 AM
hbtdawgs
Feb 8, 2006 05:39 PM
