A.T. fluid lines to radiator
Old Jun 18, 2007 | 03:40 PM
Painter's Avatar
I need to replace the radiator of a 1996 Saturn twin-cam. The A.T. fluid lines appear impossible to remove at the radiator. Would apreciate advice. Also on replacing those lines at the tranny as I'm pretty sure that they will break due to the extreme rust.
Also hints for buying new Saturn parts cheap.
Thanks. [img]smileys/smiley5.gif[/img]
Old Jun 18, 2007 | 07:13 PM
First add WD-40 a few times or many times a day before your ready to start the job, Buy yourself the proper size FlareNutWrench in hopes that you do not round off the trans line nut. Take it easy move it back and forth.Edited by: sw2cam
Old Jun 19, 2007 | 06:14 AM
boostinSC2's Avatar
you can also disconnect the tranny fluid lines from the trans, iirc, they are plastic clips, and once you get them undone, you can remove the radiator and have alittle more room and leverage to remove the tranny lines from the radiator without mangaling them
bjking
Jan 19, 2014 01:41 PM
purplemotoman
Aug 3, 2013 08:25 AM
blue99sc2
Nov 1, 2007 08:54 PM
sharkbait
Jun 15, 2007 04:31 PM
dbswayne
May 20, 2007 08:00 AM
