stumbles and misses after start up
Old Feb 19, 2008 | 06:59 PM
taylor's Avatar
I need help. I have a 1995 saturn sl-2 automatic tranny with 118,000. When I first start the car it runs strong no problems. after about 2 to 3 miles it starts to stumble and hesitate. If i give more throttle than needed it seems to pick back up but once it shifts back into drive the stumble and running roughly is back. I have changed the ects and wire connection with new dealer parts. I have taken the throttle body off and thoroughly cleaned. I have taken the egr valve off and cleaned it also. I have put new plugs in. I have not changed the plug wires or coils. If i hold the throttle at at a steady rpm it will run roughly then smooth out for a split second and then start missing and so on. The check engine light is not on and no codes are stored or pending. Any suggestions would be helpful.< ="text/"> uacct = "UA-939292-47";
urchinTracker();
Old Feb 20, 2008 | 01:01 PM
Low Saturn's Avatar
Are you getting good spark from the coil packs? Hows the fuel pressure?
Old Mar 8, 2008 | 08:20 PM
joesfiero's Avatar
Fuel pump. Definitely check the fuel pressure.
-JOE
kacfiz
Aug 24, 2015 10:41 PM
kacfiz
Dec 9, 2013 12:13 AM
jmc8338
Sep 20, 2011 04:09 PM
camaronut
Mar 25, 2008 07:51 AM
nuwt
Mar 16, 2006 06:34 PM
