Shimmy in 2003 Ion
Old Jun 23, 2009 | 11:24 PM
jhildebrand528's Avatar
Question Shimmy in 2003 Ion
I have a 2003 Saturn Ion 2 (5-speed) with 118000kms. Lately it has been starting to really shimmy at hightway speeds and I can really feel it on the steering wheel and see the wheel shake if I take my hands off. There is a slight knocking coming from somewhere inside the front of the car. This has been tough to diagnose because it only does it about 50% of the time, and seems to stop when I am turning. Does anybody have any clues?
Old Jun 23, 2009 | 11:48 PM
90% of the time a shimmy in the steering wheel is caused by tires/wheels that need to be balanced.
The first thing to check as to the knocking noise would be the front swaybar bushings.
Old Jun 25, 2009 | 12:32 PM
I have already replaced the sway bar bushings a few months ago. While this knock is similar, it is not quite the same.
Old Jun 26, 2009 | 10:18 PM
I guess you did not inform us when you made your post that swaybar bushings had been replaced, still I'd check them.
Old Jun 27, 2009 | 07:25 AM
Check the boots on your CVCC joints - make sure they are not torn/ripped/missing. Jack the front, and check for excessive play/slop in the CVCC joints ......
Old Jun 27, 2009 | 01:14 PM
How do you check the sway bar bushings without just replacing them? When I replaced the other ones, they didn't even look worn.
As for the shimmy, if something was out of balance, why would it only do it half the time? I agree though, that is exactly what it feels like.
Old Jul 5, 2009 | 12:04 PM
gunz4all's Avatar
Default Shake Rattle and Roll
Take it to an alignment shop. A good one. Strut suspensions are very sensitive creatures. Specs are one thing, but the real world is another. Tires are spin balanced to 55-65 MPH and cheap tires are sometimes not always round at these speeds. Have the run out checked. All this stuff will transmit into the steering wheel. Good Luck.
saturnion2003
Jan 16, 2013 05:59 AM
Mears
Apr 9, 2011 10:35 PM
robwarner85
Jan 16, 2010 11:09 AM
Larry Jenkins
May 3, 2009 07:44 PM
