saturn wont start
Old May 30, 2011 | 08:19 PM
sammy_09's Avatar
Default saturn wont start
I have an SL1 2001 saturn I drove my car today and it was fine I came home for an hour and when I went to leave agin it wouldn't start, the battery is fine, I checked all the fluids it all seems to be fine. It just had a tune-up a month ago. When I try to turn it on it won't even try to turnover, the lights work, along with the radio, ac. It is a manual transmission I need suggestions it is also reading the codes p1404 and p0301.
Old May 30, 2011 | 09:54 PM
Suspect battery or battery cable corrosion.
Get battery checked and check positive cable for acid corrosion.
You don't get any warning on S cars when the battery loses a cell.
You just get silence.
As for your codes -- did these exist before the no start condition?
P1404 is an EGR code:
http://www.saturnfans.com/forums/showthread.php?t=28313
P0301 is a cylinder 1 misfire --check wire for tightness and plug for fouling (for starters)
How does it idle and how much oil does it burn?
Old Jun 1, 2011 | 10:27 AM
Single Cam as in a SL1 you may, and most likely have a leaking intake manafold gasket where it bolts to the head. COMMON
SL2
May 30, 2024 08:34 PM
davidbloom
Jul 16, 2012 07:14 AM
TinkerAB
Mar 28, 2012 06:54 PM
br4nd0n
Dec 14, 2010 08:22 PM
callousparade
Jul 17, 2009 02:42 PM
