One LAST question on brake bleeding...
Thanks for being patient with all my questions, esp. on all the brake work I've done. I'm going to bleed my brakes hopefully one final time to get any more air out of the system. The question I have is when I do the two-man way of bleeding with my son at the brakes, do I put a block (lay a brick or 2x4 piece of wood) underneath the pedal so it doesn't go all the way down to the floor when he holds it down after pumping it 3-4 times, or do I let him hold it down as low as it goes, even all the way to the floor? I've been doing research and I've seen advice on both ways, what do you guys think will give me the best results?
Pump it up, open the right rear bleeder, push to floor slowl & steady, hold pedal down close bleeder, do that a few times keeping an eye on fluid level..
Next
left rear
Next
right front
Next
left front
Next
left rear
Next
right front
Next
left front
