Leaky Rear Window?
Old Mar 8, 2012 | 12:03 AM
choover82's Avatar
Default Leaky Rear Window?
My sister found out the hard way that the back window has a leak somewhere. She thought it was her imagination but when she exited the car, her rear was wet. Used a blanket to cover the seat. When we got home, I checked, and sure enough, half of the seat and backrest was wet. Me being curious, I popped the trunk to see if it was wet back there, and it was.
Im going to take the leap and say my window is leaking somewhere...anyone know of an easy fix? Dont want to take to a shop for something I can do myself. Was thinking of applying some kind of clear sealant around the window seal but want opionions first.
I did see yesterday that there is dried white dust, (water?), on the top of the window seal...maybe this is where my leak would be located. Sounds about right, now thinking about it, it is above the area where the seat is wet.
Ill take some pics of the car when the day is nicer...hopefully this weekend.
Thanks for the help =)
(oh, and someone was right, the car does burn oil, but not bad)
Old Mar 8, 2012 | 03:40 AM
If you have not switched to using a heavier weight oil, it is at least time to do it now. While it won't fix the wear that has taken place already it may defer further wear and may also slow down the oil consumption.
Yes you can get oil that is too heavy for the temperature ranges you live in. A 10W30 is an acceptable oil wieght for those who live where it snows in the winter.
A 10W40 is better if your winter does not have snow or use it in the summer.
Last Feburary it hit 80+ degrees where I live. I use 20W50 weight oil in mine. Year around. The factory recommended oil was not recommended with engine reliability in mind and needs to be changed to insure long term reliability.
As to the window? The only really good way to repair a window leak is to remove the window and replace or recondition the rubber seal or something similar.
Also if the car has a sun roof, there are drain holes in the opening with tubes that run down. You might want to check to see if they are plugged. This causes water to collect there and end up where you don't need water to be.
This is also a reason to buy a Mitchel or Chilton or someones Saturn Service manual to inform you how to do these things if you have never done them before.
Old Mar 8, 2012 | 12:13 PM
Does the car have a SUNROOF?
Old Mar 9, 2012 | 12:37 AM
choover82's Avatar
nope, it doesnt
Old Mar 9, 2012 | 06:48 AM
I guess it's possible that the rubberized gasket around the rear window has hardened over time and developed a crack, which would allow water intrusion. The use of "rubberized sealants" to stop such leaks seldom (if ever) look like a professional job.
Were it my car, I'd be calling my local "Saturn friendly" GM dealer, to (1) find out the price on a replacemant gasket, and (2) see who they would recommend to make it happen. More expensive that way, but more satisfying ....
Old Mar 9, 2012 | 04:50 PM
geek1488's Avatar
id call a local window company some times the they have a universal seal that they use when replacing windows which they used when i had the windshield replaced on my blazer other wise the will order a seal to fit i wouldnt think it would be too expensive other wise clear silcone does work but it dont look the greatest n ive never seen it solve the problem for long when it comes to windows id let a pro do it n dont stick with the first place you call shop round
Old Jul 3, 2012 | 11:36 PM
sc81's Avatar
Default Rear window leak
Our L300 had a rear window leak and we found that there was no rubber washer under the antenna just in front of the rear window. We placed a washer there and voila, no leak for the last 6 years.
Old Jul 8, 2012 | 07:57 PM
trike1946's Avatar
As a temp fix you can use some clear sealer to stop the water from coming in. But get the right gasket and do it over.
marcbarnhart
Jan 21, 2013 08:25 PM
redvue
Dec 2, 2011 11:19 AM
salatjm
Mar 15, 2009 08:59 AM
Fireball69
Jul 28, 2006 06:49 PM
pepsiman
Mar 28, 2006 06:13 PM
