intermittent start problems
Old Jan 20, 2009 | 01:57 PM
tsparks's Avatar
I have a 98 Saturn SL with a 1.9l. Have been having starting problems for a month or so. I can go start it in the morning starts fine when I leave work it starts fine, If I try to drive it within a couple hours of shutting it off it wont start, turns over fine. If I hold the throttle wide open it will fire and then die right away. After repeating this for about 15 min I can finally get it started but runs real rough for a few seconds. I changed the crank position sensor about two months ago when I had similar problems but at that time I could always get it started right away just had to hold wide open throttle. Any ideas? The car has170k on it but runs great when it runs. Any help would be greatly appreciated
Old Jan 20, 2009 | 03:13 PM
ETCS and connector.
Old Jan 20, 2009 | 04:04 PM
tsparks's Avatar
Thank you Ill give it a shot!
Old Jan 20, 2009 | 09:52 PM
tsparks's Avatar
That did it Thank you.
Old Jan 20, 2009 | 10:24 PM
Glad to hear you are back running again ...
rbwck
May 16, 2010 10:59 PM
mcrox007
Jan 12, 2010 02:32 AM
ausemma2
Feb 19, 2009 08:05 PM
laidout89
Sep 15, 2008 09:41 AM
bluchev
Jan 15, 2008 09:25 AM
