Instrument Cluster
Old May 8, 2012 | 03:31 PM
'98 Saturn SC2's Avatar
Default Instrument Cluster
Could I swap the DOHC cluster with my SOHC cluster? Would the connectors be the same on the back?
Old May 9, 2012 | 11:06 AM
I remember someone wanting to do that years ago .... I do not remeber the outcome. Maybe search around the forums a little, and if you find nothing .... give it a try. If you do it, post it on here so others have the info.
Old May 9, 2012 | 11:16 AM
I just got the whole saturn factory shop manual, I looked at the connectors and there isnt any specific connector for dohc or sohc, there just connectors.
I have another set of gauges lying around waiting to be put in my car, i can get a pic of the connectors so you can check and be sure
(I actually have a spare DOHC cluster from a 98 and from a 99 - both digital odometer - sitting around. Ill have the one from 99 once I get the homecoming gauges in my car)
Old May 9, 2012 | 07:06 PM
Okay I'll see what I find. It seems like they are both the same. I'm going to the junkyard to find a dohc cluster with a digital odometer. Hopefully I find something. I'll post about the outcome of the project.
Old May 9, 2012 | 10:45 PM
If you dont find one, Ill be more than happy to sell you one of mine
Old May 10, 2012 | 09:54 AM
That'd be sweet bro, thanks! I'll let you know if I find one.
Old Dec 3, 2012 | 05:13 PM
Is it possible to fit an 04 Ion cluster into a 98 SC? I know it may be far fetched, but I thought I'd ask to see if anyone has done it or heard of it.
Old Dec 3, 2012 | 05:16 PM
Nothing other than the battery will bolt into a S car from the ION
Old Dec 3, 2012 | 11:39 PM
SilverCoupe#SC2's Avatar
I was gonna say if you have a 3rd gen SC2 you have slightly more options with instrument clusters. I was searching around and i stumbled upon this on sixthsphere and someone did an entire list of the clusters that can be swapped. No wiring required, its all plug-n-play https://www.saturnforum.com/forum/pi...&pictureid=590
Old Dec 4, 2012 | 06:33 AM
That list was posted on here also.........................so if anyone runs across it be sure to repost in one of the S forums.
