Instrument Cluster
Could I swap the DOHC cluster with my SOHC cluster? Would the connectors be the same on the back?
I remember someone wanting to do that years ago .... I do not remeber the outcome. Maybe search around the forums a little, and if you find nothing .... give it a try. If you do it, post it on here so others have the info.
I just got the whole saturn factory shop manual, I looked at the connectors and there isnt any specific connector for dohc or sohc, there just connectors.
I have another set of gauges lying around waiting to be put in my car, i can get a pic of the connectors so you can check and be sure (I actually have a spare DOHC cluster from a 98 and from a 99 - both digital odometer - sitting around. Ill have the one from 99 once I get the homecoming gauges in my car) |
Okay I'll see what I find. It seems like they are both the same. I'm going to the junkyard to find a dohc cluster with a digital odometer. Hopefully I find something. I'll post about the outcome of the project.
Originally Posted by '98 Saturn SC2
(Post 30633)
That'd be sweet bro, thanks! I'll let you know if I find one.
Is it possible to fit an 04 Ion cluster into a 98 SC? I know it may be far fetched, but I thought I'd ask to see if anyone has done it or heard of it.
Nothing other than the battery will bolt into a S car from the ION
I was gonna say if you have a 3rd gen SC2 you have slightly more options with instrument clusters. I was searching around and i stumbled upon this on sixthsphere and someone did an entire list of the clusters that can be swapped. No wiring required, its all plug-n-play https://www.saturnforum.com/forum/pi...&pictureid=590
That list was posted on here also.........................so if anyone runs across it be sure to repost in one of the S forums.
