Idle is running high
Old Oct 13, 2007 | 08:58 PM
grreed247's Avatar
I have a 1995 SL1, the idle is high after driving a short or long distance, @ 1.5K to 3k, then slowly goes down to @ 1.2K. When this happens the linkage is in the closed position. Does anyone know what could be causing the high idle? Thanks in advanced
Old Oct 14, 2007 | 01:59 PM
Dirty throttlebody
Old Oct 14, 2007 | 02:51 PM
grreed247's Avatar
Do you think it is the IAC valve? I was thinking of taking it out and cleaning it, or should I get carb cleaner and spray the inside of the throttle body?
Old Oct 14, 2007 | 08:11 PM
ducky's Avatar
While your taking apart the throttle body to clean the IACV (clean only with electrical contact cleaner) have you checked for the original engine coolant temperature sensor, prone to cracking and usually leaving a high idle rich mixture all the time? I believe yours has two, one for dash panel (single wire) and the important one, the engine two-wire sensor that should be replaced along with the two-wire connector if its corroded from anti-freeze. Replace the sensor with the permanent brass one, the connectorfrom a pc connector, junk yard air intake temperature connector or dealer's $30 part. You might be surprised when the warmed up idle returns to a normal 800-900rpm.
Old Oct 15, 2007 | 07:31 AM
grreed247's Avatar
Thanks I'll check into that.
Old Oct 17, 2007 | 02:22 PM
grreed247's Avatar
The temp sensor took care of the problem. My idle goes down to 900 - 700 RPM's now. Thanks again!
cloudsplitter8
Aug 24, 2012 07:47 PM
Raven
May 1, 2008 11:41 AM
Robkevin
Mar 11, 2006 02:52 AM
pexmaster
Mar 11, 2006 02:40 AM
henrylford
Jan 31, 2006 01:12 AM
