How do i change spark plugs in a L200
Old Jul 14, 2007 | 01:54 PM
petes343434's Avatar
How do i change spark plugs in a 2003 L200 with a 2.2L 4 CylinderEcotec engine? Step by step instruction would be great. I have changed spark plugs on many cars before, but i a hesitant to change this car spark plugs because it looks like i have to remove some parts to get to them. Any help would be great.
Old Jul 20, 2007 | 09:01 PM
saturntech's Avatar
you must remove the 4 10mm bolts that hold on the coil pack atop the cam cover and unplug it then pull the coil pack up and the plugs are right there,thoose plugs are good for 100k
Chris
Old Jul 21, 2007 | 11:03 AM
thanks!
Old Feb 14, 2020 | 12:08 PM
Wiseman Kufa's Avatar
Chris
Which way you turn the spark plugs
Old Feb 14, 2020 | 02:01 PM
Counterclockwise to remove. Cold engine, they will be tight. There is a torque spec for the new ones about 15 ft/lbs.
Old Feb 15, 2020 | 10:51 AM
Drizz,
I know you got City Problems in Diego
but a sense of direction? Aww pleeeease no
Lefty Loose y
Righty Tight y
Not Some Thing
You should take lightly
Fifty percent
chance you make it
Fifty Percent
chance you break it
gap them things
if you gonna Re Place it
Problem with the D Kid
No sense of tone
Dude's on an infinite
monotone
Not all need be melodic
But drone on all static
just not episodic
Query Sattys
Pls don't Spit a Lot, Sir
Not here for thatty?
Best move along in your big blue caddy
ccbst10
Mar 6, 2025 12:55 PM
mozzer
Aug 14, 2019 04:24 AM
Larry Jenkins
May 3, 2009 07:44 PM
daysu47
Jul 17, 2008 09:21 AM
