Gear shift
Old Oct 23, 2014 | 02:43 PM
Jmen34's Avatar
Default Gear shift
I have an 08' saturn astra xe. I thought my battery was dead and called for a jump. Well, the tech said it's not the battery it's my automatic gear selector. When I park it won't start. Bit when he put it in neutral it started. I called gm to see if their was a recall and there isn't one. Is this expensive to fix?
Old Oct 23, 2014 | 03:03 PM
No idea .... not sure what's wrong.
Old Oct 23, 2014 | 06:11 PM
sounds like a sensor is wither our of alignment/adjustment or defective.
You can search the web for technical service bulletins (TSB) yourself on the net. They're internal manufacturer's documents that are distributed to techs or kept on file. If you come in with a problem matching a ts, they are supposed to follow whatever it says to do--sometimes a free fix, sometimes not
Let us know what you find and how it turns out.
Old Oct 24, 2014 | 11:54 AM
Sounds like it may be the Neutral Safety Switch. Call dealer for pricing.
Old Oct 24, 2014 | 11:55 AM
PS: If you plan on using this site stop in the new member sub forum and introduce yourself to the gang.
Add a SIGNATURE. Top right next to your user name click on the drop down. Add your first name, location, and car. Get your post count up to TEN asap, or your account will be gone. Once you get 25 posts sw2cam will make you an avatar on request.
Old Oct 24, 2014 | 12:46 PM
You'll fiNd not many people bought an ASTRA. That is the reason they were sold one year in the U.S. Any help you can get is going to be to your advantage.
REMEMBER
AuraTexas07XE
Saturn Aura
12
May 16, 2025 12:58 PM
arizonaaz
Jun 29, 2011 08:01 AM
Ender
Nov 15, 2010 12:11 AM
hkn royalt
May 15, 2008 11:51 PM
CALegalVette
Sep 4, 2007 07:34 AM
