Gear shift
I have an 08' saturn astra xe. I thought my battery was dead and called for a jump. Well, the tech said it's not the battery it's my automatic gear selector. When I park it won't start. Bit when he put it in neutral it started. I called gm to see if their was a recall and there isn't one. Is this expensive to fix?
sounds like a sensor is wither our of alignment/adjustment or defective.
You can search the web for technical service bulletins (TSB) yourself on the net. They're internal manufacturer's documents that are distributed to techs or kept on file. If you come in with a problem matching a ts, they are supposed to follow whatever it says to do--sometimes a free fix, sometimes not
Let us know what you find and how it turns out.
PS: If you plan on using this site stop in the new member sub forum and introduce yourself to the gang.
Add a SIGNATURE. Top right next to your user name click on the drop down. Add your first name, location, and car. Get your post count up to TEN asap, or your account will be gone. Once you get 25 posts sw2cam will make you an avatar on request.
arizonaaz
Jun 29, 2011 08:01 AM
