Easiest way to deal with rusted cat con / resonator flange exhaust stud nuts (DIY)
Old Oct 27, 2019 | 08:23 AM
Default Easiest way to deal with rusted cat con / resonator flange exhaust stud nuts (DIY)
Hi.
I have a 97SC2 with 256K on the clock.
My flex pipe developed a hole.
Since I don't own a welder nor can I weld, I purchased a single part that goes from manifold to resonator -- flange to flange.
Hit all the fasteners with blaster. The nuts come off the studs at the manifold but the cat con to resonator fasteners are hopelessly rusted in place.
3/4 of a can of blaster and 4 hours later, I can see the heads of the fasteners but they have eroded/rusted away such that I have no socket metric or standard that will fit them.
Even if I did, I doubt they would come loose.
Need to save the resonator.
Cat is still good, so I would like to save that. Car con flange may get wrecked during removal and I can accept that.
What's the best way to separate the rusted fasteners and the cat con flange from the resonator flange?
Thoughts include
torch (never used one)-- heat and fatigue
pneumatic cutoff wheel with undersized compressor
cut nuts of ends, pound remaining piece of stud out
cut just forward of cat flange, then drill out w cutting fluid.
Work area=my garage (which now reeks of PB blaster)
Thanks
Thanks
Old Oct 27, 2019 | 11:07 AM
Heat is your friend with rust. Good quality name brand vice grips.
Or find a friendly exhaust shop that will remove the bolts and install new ones you can then remove with a wrench.
Old Oct 27, 2019 | 01:23 PM
thank you, sir
Old Oct 27, 2019 | 06:37 PM
I agree 100% with Andy. A propane torch can be a good investment. Heat the bolts until they glow red, attach the vise grips and turn counter clockwise. See what happens.
Timtheelite2025
Mar 21, 2019 08:37 AM
BigShoes
Jan 5, 2016 07:58 AM
Dave4422
Nov 30, 2015 08:59 PM
Maroon97SL
Jun 6, 2011 05:22 PM
RichardMc
Jul 28, 2010 06:18 AM
