Clutch question
The bearing on my 99 seems to be going bad. What is an average price to replace the clutch? Is it something I can do myself? I have replaced them in rear wheel drive cars but not in front wheel drive. Seems like a big problem. Thanks for any help.
Unless you find something else that needs it, I'd just replace the clutch, pressure plate and throw out bearing. Take a good look at the flywheel and make sure it's not cracked or burned. If it is, you may be able to get it turned at your local machine shop.
