Cheap place to buy saturn parts?
Old Jan 27, 2009 | 11:08 AM
salesman11's Avatar
Hello,
Any one know of a good place to buy dealer only type parts?
And is there an easy way to test the air pump on a 2000 sl2.
(It dosn''t turn on, with-in the first 5 minutes of warm up. But I don''t know if its the pump or the wiring or something else. Part #2101 5056.)
I get error P0410 Secondary air injection system. (I read its ususally the valve. So I''m replacing that, and the solenoid since its cheap and will see if that fixes it. )Edited by: salesman11
Old Jan 27, 2009 | 12:13 PM
Some of the individuals here are dealers in Saturn parts. Also, you might check your local U-PULL-IT yards to see if they have ''experienced'' parts available ...
Old Jan 27, 2009 | 04:10 PM
Low Saturn's Avatar
www.saturnparts.com or www.getsaturnparts.com are reputable places to get OEM Saturn parts at pretty good prices.
And a P0410 is usually caused by carbon build up. If you remove the pipe that connects the air injection valve to the manifold port, you''''ll probably find it will be clogged with carbon.
Edited by: Low Saturn
BoboVicus
Dec 10, 2012 08:43 AM
afunbee
Oct 27, 2010 09:06 AM
mikes 1994 z28
Jul 8, 2009 06:15 PM
dmansl2
Mar 17, 2006 05:47 PM
