Hello, Any one know of a good place to buy dealer only type parts? And is there an easy way to test the air pump on a 2000 sl2. (It dosn''t turn on, with-in the first 5 minutes of warm up. But I don''t know if its the pump or the wiring or something else. Part #2101 5056.) I get error P0410 Secondary air injection system. (I read its ususally the valve. So I''m replacing that, and the solenoid since its cheap and will see if that fixes it. )Edited by: salesman11 |
Some of the individuals here are dealers in Saturn parts. Also, you might check your local U-PULL-IT yards to see if they have ''experienced'' parts available ...
www.saturnparts.com or www.getsaturnparts.com are reputable places to get OEM Saturn parts at pretty good prices.
And a P0410 is usually caused by carbon build up. If you remove the pipe that connects the air injection valve to the manifold port, you''''ll probably find it will be clogged with carbon. Edited by: Low Saturn |
